netfilter_conntrack_full
OS: Linux
This alert presents the percentage of used netfilter tracked connections.
If you receive this alert, there is high utilization of the netfilter “connection tracking state” table size.
Network delays and packet drops are expected when you are getting closer to 100%.
- This alert gets raised to warning when the percentage exceeds 90%.
- If the metric exceeds 95%, then the alert gets raised to a critical state.
What is the "netfilter" framework
Netfilter is a framework provided by the Linux kernel that allows various networking-related
operations to be implemented in the form of customized handlers. Netfilter offers various
functions and operations for packet filtering, network address translation, and port
translation, which provide the functionality required for directing packets through a network
and prohibiting packets from reaching sensitive locations within a network.1
References and Sources
Troubleshooting Section
Table Size Limits
You can see the table size by running:
root@netdata~ # cat /proc/sys/net/netfilter/nf_conntrack_count
You can see the table size limit by running:
root@netdata~ # cat /proc/sys/net/netfilter/nf_conntrack_max
Recommended Size: CONNTRACK_MAX = RAMSIZE (in bytes) / 16384 / (ARCH / 32).
Eg, If we have 8GB RAM in a x86_64 OS, we would use 8*1024^3/16384/2=262144. 2
You can modify the table size limit by running:
root@netdata~ # sysctl -w net.netfilter.nf_conntrack_max=<YOUR DESIRED LIMIT HERE>
root@netdata~ # echo "net.netfilter.nf_conntrack_max=<YOUR DESIRED LIMIT HERE>" >> /etc/sysctl.conf
