tcp_connections
OS: Linux
This alert presents the percentage of used IPv4 TCP connections. If you receive it, it is an indication of high IPv4 TCP connections utilization.
If this value is 100% then the system is no longer able to establish new TCP connections.
- This alert is raised to a state of warning when the percentage of used IPv4 TCP connections is
greater than 80% and less than 90%. - If the percentage of used IPv4 TCP connections exceeds 90%, then the alert gets raised to critical.
TCP Connections Alarm Settings
Inside the tcp_conn.conf, on the calc: line, there is this block of code:
(${tcp_max_connections} > 0) ? ( ${connections} * 100 / ${tcp_max_connections} ) : 0
- That line of code will calculate the value of
$thisin the following lines. - Essentially, if the max connections are not dynamic, and there is a limit, then we calculate the
percentage of used IPv4 TCP connections. Otherwise, we have a dynamic threshold
(so${tcp_max_connections}may be nan or -1), which in this case the alert and$thiswill
always be zero.
