Suggested template:
Oracle DB integration, the sessions charts not showing any incoming data.
docker compose installation with stable image
to see ih the charts activity on Sessions like I can see in logons. I am facing the same in some more charts.
The database is also dockerized and the version is 19c.
The SQL I run are
CREATE USER netdata IDENTIFIED BY pass;
GRANT CONNECT TO netdata;
GRANT SELECT ON v_$sysmetric TO netdata;
GRANT SELECT_CATALOG_ROLE TO netdata;
GRANT SELECT ON v_$sysstat TO netdata;
GRANT SELECT ON v_$waitclassmetric TO netdata;
GRANT SELECT ON v_$system_wait_class TO netdata;
GRANT SELECT ON dba_data_files TO netdata;
GRANT SELECT ON dba_free_space TO netdata;
GRANT SELECT ON dba_segments TO netdata;
GRANT SELECT ON dba_temp_files TO netdata;
GRANT SELECT ON dba_tablespaces TO netdata;
GRANT SELECT ON v_$temp_space_header TO netdata;
GRANT SELECT ON v_$session TO netdata;
any help is appreciated
– sorry if I am not following any rules on typing the issue, is my first one , thanks
