My question was asked before on the forum, but the solution there doesn’t help me.
parent side error:
STREAM_RECEIVER for 'test-app-server': API key is not enabled.
Child side Error:
STREAM prod-app-server [send to 172.16.XXX.XX]: remote server denied access, probably we don't have the right API key? -
Parent
OS: Ubuntu Server 2024 LTS
Netdata version: netdata v1.46.0-311-nightly (installed via Kickstarter)
Config:
netdata.conf - all standard values except:
[web]
allow connections from = localhost 172.16.152.*
bind to = 127.0.0.1 172.16.152.64
allow netdata.conf from = localhost 172.16.152.*
stream.conf - all standard values except:
[stream]
enabled = yes
api key = 11111111-2222-3333-4444-555555555555
[API_KEY]
type = api
enabled = yes
allow from = *
Child
Config:
[web]
bind to = 127.0.0.1 172.16.152.63
[stream]
enabled = yes
destination = 172.16.152.64:19999
[API_KEY]
type = api
enabled = yes
allow from = *
Both machines appear to see each other and communicate. Only the message on the parent side “API key is not enabled” is not understandable. The API key is already enabled.
The same applies to the child site. The message “remote server denied access, probably we don’t have the right API key?” is misleading. Both keys (parent/child) are identical.
The file encoding is the same for all configuration files (text/plain; charset=us-ascii). This allows me to exclude a file encoding error.
Both machines are in the same network and at the local net all ports are open in the firewall.
But what could be the problem? Does anyone have the same problem with a similar configuration?
