api key disabled permission denied
Good afternoon, I have installed a virtual machine with netdata, and then I tried to add another Linux machine via the API to monitor my main application. The problem is that the machine does not appear on the dashboard. Through logs, I see that the machine manages to connect, but this error message appears in the logs: API KEY DISABLED PERMISSION DENIED.
This is the server configuration file;
run as user = netdata
# default storage size - increase for longer data retention
page cache size = 32
dbengine multihost disk space = 256
[stream]
enabled = yes
destination = 172.21.56.55
api key = *******
enabled = yes
allow from = 172.21.56.82
default history = 3600
default memory mode = ram
and this is the client machine I want to monitor
[stream]
enabled = yes
destination = 172.21.56.55:19999
api key = ******
timeout seconds = 60
default port = 19999
default memory mode = save
send charts matching = *
buffer size bytes = 1048576
Hi @David_Tapias
I would maybe pinpoint this to a missing entry type = api that should be in the parent’s config under the section of the api key.
Also, just to make sure, that you have a stream.conf file on both the parent and the child, right? The stream related configuration should be in it’s own file (stream.conf). While in /etc/netdata you can user ./edit-config stream.conf to make sure things are in place.
In my case, I still don’t know why, the entry [API_KEY] was reset on my parent. I’ve just put it back on stream.conf.
To debug this, you can temporary enable it on parent for all the API keys
# You can disable the API key, by setting this to: no
# The default (for unknown API keys) is: no
enabled = yes
The issue was using the stock stream.conf.
