Hi Odysseas
Since it’s a huge file. Here is the relevant section on the master collator side for the netdata.conf file
        run as user = netdata
        history = 3996
        process scheduling policy = idle
        OOM score = 1000
        stock config directory = /etc/netdata/conf.d
        # glibc malloc arena max for plugins = 1
        # glibc malloc arena max for netdata = 1
        # hostname = removed.by.author
        # update every = 1
        # config directory = /etc/netdata
        # log directory = /var/log/netdata
        # web files directory = /usr/share/netdata/web
        # cache directory = /var/cache/netdata
        # lib directory = /var/lib/netdata
        # home directory = /var/log/netdata
        # lock directory = /var/lib/netdata/lock
        # plugins directory = "/usr/libexec/netdata/plugins.d" "/etc/netdata/custom-plugins.d"
        # memory mode = dbengine
        # page cache size = 32
        # dbengine disk space = 256
        # dbengine multihost disk space = 256
        # host access prefix =
        # memory deduplication (ksm) = yes
        # TZ environment variable = :/etc/localtime
        # timezone = Australia/Melbourne
        # debug flags = 0x0000000000000000
        # debug log = /var/log/netdata/debug.log
        # error log = /var/log/netdata/error.log
        # access log = /var/log/netdata/access.log
        # facility log = daemon
        # errors flood protection period = 1200
        # errors to trigger flood protection = 200
        # pthread stack size = 8388608
        # cleanup obsolete charts after seconds = 3600
        # cleanup orphan hosts after seconds = 3600
        # delete obsolete charts files = yes
        # delete orphan hosts files = yes
        # enable zero metrics = no
[web]
        web files owner = root
        web files group = netdata
        bind to = 0.0.0.0
        # ssl key = /etc/netdata/ssl/key.pem
        # ssl certificate = /etc/netdata/ssl/cert.pem
        # tls version = 1.3
        # tls ciphers = none
        # ses max window = 15
        # des max window = 15
        # mode = static-threaded
        # listen backlog = 4096
        # default port = 19999
        # disconnect idle clients after seconds = 60
        # timeout for first request = 60
        # accept a streaming request every seconds = 0
        # respect do not track policy = no
        # x-frame-options response header =
        # allow connections from = localhost *
        # allow connections by dns = heuristic
        # allow dashboard from = localhost *
        # allow dashboard by dns = heuristic
        # allow badges from = *
        # allow badges by dns = heuristic
        # allow streaming from = *
        # allow streaming by dns = heuristic
        # allow netdata.conf from = localhost fd* 10.* 192.168.* 172.16.* 172.17.* 172.18.* 172.19.* 172.20.* 172.21.* 172.22.* 172.23.* 172.24.* 172.25.* 172.26.* 172.27.* 172.28.* 172.29.* 172.30.* 172.31.* UNKNOWN
        # allow netdata.conf by dns = no
        # allow management from = localhost
        # allow management by dns = heuristic
        # enable gzip compression = yes
        # gzip compression strategy = default
        # gzip compression level = 3
        # web server threads = 6
        # web server max sockets = 256
And this is from the stream.conf file
[stream]
    # Enable this on child nodes, to have them send metrics.
    enabled = no
    # Where is the receiving netdata?
    # A space separated list of:
    #      [PROTOCOL:]HOST[%INTERFACE][:PORT][:SSL]
    # If many are given, the first available will get the metrics.
    # PROTOCOL  = tcp, udp, or unix (only tcp and unix are supported by parent nodes)
    # HOST      = an IPv4, IPv6 IP, or a hostname, or a unix domain socket path.
    #             IPv6 IPs should be given with brackets [ip:address]
    # INTERFACE = the network interface to use (only for IPv6)
    # PORT      = the port number or service name (/etc/services)
    # SSL       = when this word appear at the end of the destination string
    #             the Netdata will encrypt the connection with the parent.
    # This communication is not HTTP (it cannot be proxied by web proxies).
    destination =
    # Skip Certificate verification?
    # The netdata child is configurated to avoid invalid SSL/TLS certificate,
    # so certificates that are self-signed or expired will stop the streaming.
    # Case the server certificate is not valid, you can enable the use of
    # 'bad' certificates setting the next option as 'yes'.
    #ssl skip certificate verification = yes
    # Certificate Authority Path
    # OpenSSL has a default directory where the known certificates are stored,
    # case it is necessary it is possible to change this rule using the variable
    # "CApath"
    #CApath = /etc/ssl/certs/
   # Certificate Authority file
    # When the Netdata parent has certificate, that is not recognized as valid,
    # we can add this certificate in the list of known certificates in CApath
    # and give for Netdata as argument.
    #CAfile = /etc/ssl/certs/cert.pem
    # The API_KEY to use (as the sender)
    api key =
    # The timeout to connect and send metrics
    timeout seconds = 60
    # If the destination line above does not specify a port, use this
    # filter the charts to be streamed
    # netdata SIMPLE PATTERN:
    # - space separated list of patterns (use \ to include spaces in patterns)
    # - use * as wildcard, any number of times within each pattern
    # - prefix a pattern with ! for a negative match (ie not stream the charts it matches)
    # - the order of patterns is important (left to right)
    # To send all except a few, use: !this !that *   (ie append a wildcard pattern)
    send charts matching = *
    # The buffer to use for sending metrics.
    # 1MB is good for 10-20 seconds of data, so increase this if you expect latencies.
    # The buffer is flushed on reconnects (this will not prevent gaps at the charts).
    buffer size bytes = 1048576
    # If the connection fails, or it disconnects,
    # retry after that many seconds.
    reconnect delay seconds = 5
    # Sync the clock of the charts for that many iterations, when starting.
# 2. ON PARENT NETDATA - THE ONE THAT WILL BE RECEIVING METRICS
#    You can have one API key per child,
#         or the same API key for all child nodes.
#    netdata searches for options in this order:
#    a) parent netdata settings (netdata.conf)
#    b) [stream] section        (above)
#    c) [API_KEY] section       (below, settings for the API key)
#    d) [MACHINE_GUID] section  (below, settings for each machine)
#    You can combine the above (the more specific setting will be used).
# API key authentication
# If the key is not listed here, it will not be able to push metrics.
# [API_KEY] is [YOUR-API-KEY], i.e [11111111-2222-3333-4444-555555555555]
[e7772f6c-06e2-4cc2-b003-5d9164c60a1f]
enabled = yes
allow from = 10.126.20.33
default history = 3600
default memory mode = ram
Then on the client sending its data
From stream.conf
[stream]
    enabled = yes
    destination = 10.126.24.167
    # "CApath"
    api key = e7772f6c-06e2-4cc2-b003-5d9164c60a1f
And it’s netdata.conf
    memory mode = none
    # the default database size - 1 hour
    history = 3600
    # some defaults to run netdata with least priority
    OOM score = 1000
[web]
    mode = none
    # by default do not expose the netdata port
    bind to = 10.126.20.33
