Ping tests stopped working suddenly. ERROR - Command not supported by configuration node.
Problem:
Ping tests stopped being recorded from the agent suddenly on Feb 21. When I went to investigate and tried to edit the Ping configuration, I was presented with the following error:
Dyncfg functions intercept: this command is not supported by this configuration node
This is exactly one month after I physically installed the unit, but over a month since the unit was actually added as a node. It is installed on a remote network in a physically inaccessible space. I have an active business license.
Any help or recommendations would be greatly appreciated!
OS Version:
Raspbian GNU/Linux, 11 (bullseye)
Netdata Agent:
v2.2.6
I think I know my issue. I only ever relied on configuring the ping test through the dynamic configuration window, but never set it up on the device itself.
Unfortunately it is very unlikely that I can get access to this device to perform the configuration change necessary.
@Flikinator. hey :waving_hand:
  • Can you take a screenshot when the error occurs?
  • Show the output of ps faxu | grep netdata.
