Since a few days netdata on Raspberry Pi 3 DNS server throws alert for less than 16% RAM free. I checked the metrics and found netdata agent to be suspect
Before that issue netdata was using about 200-300MB RAM. I changed some settings to reduce resource usage, but netdata is still filling up the whole available RAM eventually. It just takes longer now that I set update every = 5.
Are there any known plugins that might cause that high memory usage? Any other way to hardcap netdata RAM usage to a defined amount? It is uploading all metrics to the cloud anyways .
Please help asap. For now, I need to restart netdata service every 6 hours or the system runs out of RAM.
edit: See how it constantly increases RAM usage but not stopping when it reaches the dbengine limit of 128M as defined in my config. This abnormal unusual behavior.
Using these settings:
update every = 2
dbengine page cache size MB = 16
dbengine disk space MB = 128
dbengine multihost disk space MB = 128
