How can I reduce the memory footprint of Netdata Agent?
Memory consumption
VPS 1CPU / 1GB RAM
Ubuntu 22.04 LTS
netdata v1.44.1
I checked netdata’s memory consumption with Netdata monitoring and metric " Resources utilization of systemd services" shows ~200MB (for netdata).
I checked /etc/netdata/netdata.conf and this config includes only few parameters:
run as user = netdata
# default storage size - increase for longer data retention
page cache size = 32
dbengine multihost disk space = 256
After reading further documentation I wonder why there’s no section db in the configuration file.
Can you please advise?
THX
ilyam8
January 5, 2024, 11:21pm
2
That is memory usage of all Netdata’s components and I believe it includes shared memory. You can see the actual memory usage in the “Applications” section “memory” subsection, check the first chart - “Apps memory usage without shared”.
There you can find Netdata and its data collection plugins - processes with .plugin suffix:
You can disable plugins in netdata.conf, check the [plugins] section.
You can decrease memory usage of Netdata process by changing in netdata.conf
[db]
dbengine page type = gorilla
Restart Netdata to apply changes.
This metric shows ~99MB for netdata.
I wonder why I should switch to dbengine page type = gorilla.
I’m running a mail server (dovecot, postfix, spamd) and think it makes sense to limit metrics for relevant application(s) running.
ilyam8
January 6, 2024, 12:20am
4
See “Gorilla compression beta” in v1.44.0 highlights . It is still beta but worth trying.
Also, if you see that ebpf.plugin uses a lot of (assuming 50-60 is a lot in your case) - disable it.
Actually I can’t see any data for ebpf.plugin in metric "Apps memory usage without shared”.
