Mauro
November 3, 2022, 11:54am
1
Hi.
On Ubuntu 20.04, I have installed the agent , then decided to uninstall it .
I followed the instructions.
Now, every day, I am getting:
run-parts: failed to stat component /etc/cron.daily/netdata-updater: No such file or directory
Which tells me something wasn’t cleaned completely.
Does anyone know the steps I could take, or which program is attempting to run this particular cron?
Thanks.
Same thing, weird. Any solutions or workaround?
This appears to be a bug in the uninstaller code.
You should be able to work around the issue by simply manually removing /etc/cron.daily/netdata-updater.
Mauro
November 4, 2022, 3:19pm
4
Thank you! Seems I misread the error message. Indeed this was caused by a leftover link in /etc/cron.daily
I did that but the server still keeps emailing me that same error code.
@Austin_Hemmelgarn I manually removed that file but I keep getting those warnings on my webserver. What else do I need to clean? Would installing netdata and uninstalling work better? Thanks
