Every night cron runs i get message from cron.daily/netdata-updater
Problem is that we have /tmp secured such that there cannot be files executed, so we use TMPDIR=/home/netdata_tmp in this netdata-updater cron. After cron has run it rm -rf /home/netdata_tmp and yes again same error message next night cron run.
Debian 11 , netdata 1.47.4
Suggested template:
Not sure if i understood [Bug] Link you sent, but netdata is installed via debian packages so i just removed daily crontab file (symlink) . Let’s see how it goes with apt package updates.
