I have a server that is doing a fstrim command every night, and during that time, I want to silence the disk alerts.
So I’m adding silencers:
Alarms list: {
"all": false,
"type": "SILENCE",
"silencers": [
"alarm": "disk_util.nvme3n1"
"context": "disk_util.nvme3n1.10min_disk_utilization"
(I’m adding both an alarm and a context silencer, just trying to get it to match something, I’ve tried other names but I can’t get anything to work).
and this is the alarm that’s still going off:
Alarms list: {
"hostname": "fqdn",
"latest_alarm_log_unique_id": 1647905719,
"status": true,
"now": 1648377809,
"alarms": {
"disk_util.nvme3n1.10min_disk_utilization": {
"id": 1647905528,
"name": "10min_disk_utilization",
"chart": "disk_util.nvme3n1",
"family": "nvme3n1",
"active": true,
"disabled": false,
"silenced": false,
"exec": "/usr/libexec/netdata/plugins.d/alarm-notify.sh",
"recipient": "sysadmin",
"source": "130@/etc/netdata/health.d/disks.conf",
"units": "%",
"info": "the percentage of time the disk was busy, during the last 10 minutes",
"status": "WARNING",
"last_status_change": 1648376654,
"last_updated": 1648377794,
"next_update": 1648377854,
"update_every": 60,
"delay_up_duration": 0,
"delay_down_duration": 900,
"delay_max_duration": 3600,
"delay_multiplier": 1.200000,
"delay": 0,
"delay_up_to_timestamp": 1648376654,
"warn_repeat_every": "0",
"crit_repeat_every": "0",
"value_string": "87%",
"last_repeat": "0",
"db_after": 1648377195,
"db_before": 1648377794,
"lookup_method": "average",
"lookup_after": -600,
"lookup_before": 0,
"lookup_options": "unaligned",
"warn":"$this > $green * (($status >= $WARNING) ? (0.7) : (1))",
"warn_parsed":"(${this} > (${green} * ((${status} >= ${WARNING}) ? 0.7 : 1)))",
"crit":"$this > $red * (($status == $CRITICAL) ? (0.7) : (1))",
"crit_parsed":"(${this} > (${red} * ((${status} == ${CRITICAL}) ? 0.7 : 1)))",
"green":90,
"red":98,
"value":87.0127922
it’s still saying ‘silenced: false’, and still sending a notification. I know it’s going to be something simple, but what am I missing?
Also, as far as I can tell, you can’t see in the GUI if something is silenced, is that right? That would be really handy to see if this would work properly.
I’m using the netdata docker image : netdata:v1.29.3 .
Thanks,
Chris.
