Slack message when node is down?
Environment
Debian 10
I’ve managed to setup my Netdata agent to send Slack messages on warnings, etc and also managed to setup the Netdata Cloud to send me mails when a node is down.
I guess Slack integration is done on the agent and if the node is down, the agent can’t really do anything.
Is it possible to receive Slack messages when a node is down?
Hi @Tudvari ! Thanks! Good suggestion. Cloud indeed is planning to provide more notification methods, and the reach-ability notifications could also be sent to other channels.
