SpringBoot Metrics data does not appear for actuator/prometheus endpoint
Suggested template:
I successfully added springboot2 metrics endpoint (actuator/prometheus).
But the NetData dashboard, only has SpringBoot2 metrics with the following:
(uptime, response_code, heap, threads).
Does the NetData agent also suppose to scrap other metrics from the above endpoint including custom metrics?
https://learn.netdata.cloud/docs/agent/collectors/go.d.plugin/modules/springboot2
Agent is running under Ubuntu host
I am expecting to see custom metrics scrapped by NetData agent and send to the NetData cloud
Hi, does anyone experience the same as this issue?
Hi, @anazri. Consider using go.d/prometheus for custom metrics.
Thanks @ilyam8
Appreciate your suggestion. It’s working now… :pray:
