system_clock_sync_state
OS: Linux
The Netdata Agent checks if your system is in sync with a Network Time Protocol (NTP) server. This alert indicates that the system time is not synchronized to a reliable server. It is strongly recommended having the clock in sync with NTP servers, because, otherwise, it leads to unpredictable problems that are difficult to debug especially in matters of security.
Here you can find a great article on best practices for NTP servers.
Troubleshooting section:
General approach
Different linux distros utilize different NTP tools. You can always install ntp. If your clock is
out of sync, you should first check for issues in your network connectivity.
