tcp_memory
OS: Linux
The Netdata Agent calculates the percentage of used TCP memory. Receiving this alert indicates that the TCP memory utilization uses more memory than the limit.
By default, the Linux network stack is not configured for high speed large file transfer across WAN links. This is done to save memory resources. System performs out of memory checks, if the memory used by the TCP protocol is higher than the third value(max) of the net.ipv4.tcp_mem, it throws OOM error. This will make some applications to become unresponsive.
See more about TCP buffers
There are 3 main parameters to configure regarding the TCP buffers.
tcp_memis a vector of 3 integers:"low, pressure, high". These bounds, measured in units of
the system page size, are used by TCP to track its memory usage. The defaults are calculated at
boot time from the amount of available memory. (TCP can only use low memory for this, which is
limited to around 900 megabytes on 32-bit systems. 64-bit systems do not suffer this limitation.)low TCP doesn’t regulate its memory allocation when the number of pages it has allocated
globally is below this number.pressure When the amount of memory allocated by TCP exceeds this number of pages, TCP
moderates its memory consumption. This memory pressure state is exited once the number of
pages allocated falls below the low mark.high The maximum number of pages, globally, that TCP will allocate. This value overrides any
other limits imposed by the kernel. 1
The min/pressure/max TCP buffer space are automatically set in /proc/sys/net/ipv4/tcp_mem during
the boot time based on available RAM size.
net.ipv4.tcp_rmemcontains three values that represent"minimum default maximum_sizeof the
TCP socket receive buffer.The minimum represents the smallest receive buffer size guaranteed, even under memory
pressure. The minimum value defaults to 1 page or 4096 bytes.The default value represents the initial size of a TCP sockets receive buffer. This value
supersedes net.core.rmem_default used by other protocols. The default value for this setting
is 87380 bytes. It also sets the tcp_adv_win_scale and initializes the TCP window size to
65535 bytes.The maximum represents the largest receive buffer size automatically selected for TCP sockets.
This value does not override net.core.rmem_max. The default value for this setting is
somewhere between 87380 bytes and 6M bytes based on the amount of memory in the system.The recommendation is to use the maximum value of 16M bytes or higher (kernel level dependent)
especially for 10 Gigabit adapters.
net.ipv4.tcp_wmemparameter also consists of 3 values"minimum default maximum".
- The minimum represents the smallest receive buffer size a newly created socket is entitled to
as part of its creation. The minimum value defaults to 1 page or 4096 bytes.- The default value represents the initial size of a TCP sockets receive buffer. This value
supersedes net.core.rmem_default used by other protocols. It is typically set lower than
net.core.wmem_default. The default value for this setting is 16K bytes.- The maximum represents the largest receive buffer size for auto-tuned send buffers for TCP
sockets. This value does not override net.core.rmem_max. The default value for this setting is
somewhere between 64K bytes and 4M bytes based on the amount of memory available in the
especially for 10 Gigabit adapters. 2
References and sources
Troubleshooting section:
Increase the TCP memory
Increasing the TCP memory available in the Linux network stack may resolve this issue.
Try to increase the
tcp_memboundsroot@netdata # sysctl -w net.ipv4.tcp_mem="819200 1091174 1638400" -
Verify the change and test it with the same workload that triggered the alarm originally. If the problem still exists, you can always consider increase it more.
root@netdata~ # sysctl net.ipv4.tcp_mem net.ipv4.tcp_mem=819200 1091174 1638400 -
If this change works for your system, you could make it permanently. Bump this entry under
/etc/sysctl.conf -
Reload the sysctl settings.
root@netdata~ # sysctl -p
