The fineness of monitor
Environment
netdata v1.31.0 Linux on my IOT device
The netdata is useful, I can use it to monitor my system conveniently. But I have to see some metric more specifically, not just on the system level, but the process or thread information.
I know that netdata may provide a method to monitor process, where can I find the examples. And if I want to monitor thread just like the window tools “Process Explorer” do, how can i do.
Find a way to use netdata to monitor process and thread. Thanks.
Welcome @HR1025 !
Is this any use to you: Monitor any process in real-time with Netdata | Learn Netdata
I think you can config the plugin to match a specific process and then have a separate dimension for that process on the relevant charts.
Thanks. I try and find it useful. Now I use netdata to monitor the major process I run my IOT device. :grinning:
