There is an issue with sending metrics to the Gnocchi server using the "prometheus_remote_write" connector.
Hello everyone,
I am trying to export metrics from a Netdata agent to a Gnocchi server. To achieve this, I have created an exporting.conf file, the contents are as follows:
[prometheus_remote_write:gnocchi_instance]
    enabled = yes
    destination = x.y.z.w:8041
    remote write URL path = /v1/prometheus/write
    data source = average
    prefix = netdata
    hostname = myhost
    username = admin
    #password = admin
    update every = 10
    buffer on failures = 10
    timeout ms = 20000
    send names instead of ids = yes
    send charts matching = *
    send hosts matching = *
My Gnocchi server uses basic authentication, and it is not required to set a password when sending requests to the Gnocchi API. I did not observe any new metrics.
When I checked the Gnocchi logs, I saw the following entry:
[pid: 14|app: 0|req: 13877/27765] 10.204.189.1 () {32 vars in 430 bytes} [Thu Feb 29 13:46:10 2024] POST /v1/prometheus/write => generated 358 bytes in 166 msecs (HTTP/1.1 401) 3 headers in 109 bytes (2 switches on core 19)
T
This entry shows that the netdata agent is sending metrics, but something is preventing them from being received by Gnocchi.
I have attempted to comment and uncomment the “user” and “password” sections in the exporting file, but it did not make any difference.
Additionally, I have installed a Prometheus server and configured it to send its metrics to the Gnocchi server for testing. All the metrics were received correctly!
Here is my prometheus.yaml file:
global:
  scrape_interval: 5s
remote_write:
  - url: "http://gnocchi-api:8041/v1/prometheus/write"
    basic_auth:
      username: admin
      password: admin
scrape_configs:
  - job_name: prometheus
    static_configs:
    - targets: ['localhost:9090']
Can anyone help me troubleshoot this issue? Thank you.
Netdata build info
netdata -W buildinfo
Packaging:
    Netdata Version ____________________________________________ : v1.44.0-412-nightly
    Installation Type __________________________________________ : oci
    Package Distro _____________________________________________ : unknown
    Configure Options __________________________________________ : dummy-configure-command
Default Directories:
Operating System:
    Kernel Version _____________________________________________ : 5.4.0-159-generic
    Operating System ___________________________________________ : Ubuntu
    Operating System ID ________________________________________ : ubuntu
    Operating System ID Like ___________________________________ : debian
    Operating System Version ___________________________________ : 20.04.6 LTS (Focal Fossa)
    Operating System Version ID ________________________________ : 12
    Detection __________________________________________________ : /host/etc/os-release
Hardware:
    CPU Cores __________________________________________________ : 4
    CPU Frequency ______________________________________________ : 2400000000
    RAM Bytes __________________________________________________ : 7730716672
    Disk Capacity ______________________________________________ : 200000012288
    CPU Architecture ___________________________________________ : x86_64
    Virtualization Technology __________________________________ : kvm
    Virtualization Detection ___________________________________ : lscpu
Container:
    Container __________________________________________________ : docker
    Container Detection ________________________________________ : dockerenv
    Container Operating System _________________________________ : Debian GNU/Linux
    Container Operating System ID ______________________________ : debian
    Container Operating System ID Like _________________________ : unknown
    Container Operating System Version _________________________ : 12 (bookworm)
    Container Operating System Version ID ______________________ : 12
    Container Operating System Detection _______________________ : /etc/os-release
Features:
Database Engines:
    dbengine ___________________________________________________ : YES
Connectivity Capabilities:
Libraries:
Plugins:
    cups (monitor printers and print jobs) _____________________ : NO
    ebpf (monitor system calls) ________________________________ : NO
    nfacct (gather netfilter accounting) _______________________ : NO
    Xen ________________________________________________________ : NO
    Logs Management ____________________________________________ : YES
Exporters:
Debug/Developer Features:
All metrics have been successfully sent to the Gnocchi server without any HTTP errors.
