Hi, I have an auto-scaling setup at AWS and trying to monitor my nodes with Netdata Cloud.
I grabbed the token and room parameters from the claiming command and added to my launch configuration template as an environment variable. With a init script, I can run netdata-claim.sh with token and room parameters at the first boot.
In my testing setup, the new machines showed up in my account effortlessly (kudos to developers) but after a while I noticed that new machines are no longer auto-claimed. Looking more closely I noticed the token is changed at the Cloud UI after a while.
The token probably has time limited for security reasons. Is there a way to support auto deployment scenarios? (Same applies for auto-unclaiming but I think this feature is not ready yet as there is a note about that in claming command UI)
Thanks!
