Unable to reply to TOPIC : linux-power-supply-capacity
Unable to repy or ask a question from a post, therefore creating post to seek answer :slight_smile:
Link : linux_power_supply_capacity
I want to suppress this alert,
Reason : I do not want to fix Physical Bettry of my sys spare system it’s ok
Hey @Evil_Paul !
You can create a custom alert from this one, then set the to: field of the alert to silent. The alert will still work, but you won’t get any notifications from it.
To do this, you can go to /etc/netdata and use sudo ./edit-config health.d/linux_power_supply.conf. On the editor that comes up, change to: to silent.
There is some more information here → Stop notifications for individual alarms | Learn Netdata
Hi @Manolis_Vasilakis !
Thank you so much it worked !!
Thanks
Ashish Thakur
Updated config file and ran [netdatacli reload-health]
and Alarm came again .
