Uninstall fails on Intel iMac
Hi
I am trying to uninstall metadata from an Inl=tel iMac, but I get the following error:
12:03 $ wget -O /tmp/netdata-kickstart.sh https://my-netdata.io/kickstart.sh && sh /tmp/netdata-kickstart.sh --uninstall
--2023-09-14 12:04:17--  https://my-netdata.io/kickstart.sh
Resolving my-netdata.io (my-netdata.io)... 188.114.96.14, 188.114.97.14
Connecting to my-netdata.io (my-netdata.io)|188.114.96.14|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/octet-stream]
Saving to: ‘/tmp/netdata-kickstart.sh’
/tmp/netdata-kickstart.sh                           [ <=>        ]  82.96K  --.-KB/s    in 0.001s
2023-09-14 12:04:17 (130 MB/s) - ‘/tmp/netdata-kickstart.sh’ saved [84946]
 --- Using /var/folders/5k/g8z_7q3d6vb54m8k0cjy940r0000gq/T/netdata-kickstart-XXXXXXXXXX.dim9AxCI as a temporary directory. ---
 --- Checking for existing installations of Netdata... ---
 --- Downloading netdata-uninstaller ... ---
[/var/folders/5k/g8z_7q3d6vb54m8k0cjy940r0000gq/T/netdata-kickstart-XXXXXXXXXX.dim9AxCI]$ /usr/bin/curl --fail -q -sSL --connect-timeout 10 --retry 3 --output /var/folders/5k/g8z_7q3d6vb54m8k0cjy940r0000gq/T/netdata-kickstart-XXXXXXXXXX.dim9AxCI/netdata-uninstaller.sh https://raw.githubusercontent.com/netdata/netdata/master/packaging/installer/netdata-uninstaller.sh
 OK
[/var/folders/5k/g8z_7q3d6vb54m8k0cjy940r0000gq/T/netdata-kickstart-XXXXXXXXXX.dim9AxCI]$ sudo /var/folders/5k/g8z_7q3d6vb54m8k0cjy940r0000gq/T/netdata-kickstart-XXXXXXXXXX.dim9AxCI/netdata-uninstaller.sh --yes
Password:
/var/folders/5k/g8z_7q3d6vb54m8k0cjy940r0000gq/T/netdata-kickstart-XXXXXXXXXX.dim9AxCI/netdata-uninstaller.sh: line 711: /etc/netdata/.environment: No such file or directory
Thu Sep 14 12:04:29 CEST 2023 : FATAL: netdata-uninstaller.sh: FAILED TO UNINSTALL NETDATA:  Failed to completely remove Netdata from this system.
 FAILED
Finished uninstalling the Netdata Agent.The following non-fatal warnings or errors were encountered:
  - Command "sudo /var/folders/5k/g8z_7q3d6vb54m8k0cjy940r0000gq/T/netdata-kickstart-XXXXXXXXXX.dim9AxCI/netdata-uninstaller.sh --yes" failed with exit code 1.
Root privileges required to run rm -rf /var/folders/5k/g8z_7q3d6vb54m8k0cjy940r0000gq/T/netdata-kickstart-XXXXXXXXXX.dim9AxCI
[/Users/rainer]$ sudo rm -rf /var/folders/5k/g8z_7q3d6vb54m8k0cjy940r0000gq/T/netdata-kickstart-XXXXXXXXXX.dim9AxCI
 OK
12:04 $
Any suggestions how I can remove netdata? It is not needed anymore on that computer.
Thanks,
Rainer
Hi @rkrug
Can we assume you initially installed using the kickstart script? Is currently netdata under /usr/sbin/netdata ?
Yes. This is the case. (as far as I remember, and homebrew Netdata is not installed - so it should be the official installer).
