Uptime monitoring started to fail on lxc
Suggested template:
Suddenly out of nowhere uptime monitoring started to fail on my lxc node.
Example:
root@vps3073748:~# service wings status
● wings.service - Wings Daemon
     Loaded: loaded (/etc/systemd/system/wings.service; enabled; preset: enabled)
     Active: active (running) since Wed 2025-06-11 07:56:40 UTC; 31min ago
   Main PID: 229056 (wings)
      Tasks: 41 (limit: 76931)
     Memory: 165.8M (peak: 452.2M)
        CPU: 29.192s
     CGroup: /system.slice/wings.service
             └─229056 /usr/local/bin/wings --debug
In netdata API it returns
array(6) {
  ["name"]=>
  string(16) "app.wings_uptime"
  ["family"]=>
  string(6) "uptime"
  ["context"]=>
  string(10) "app.uptime"
  ["units"]=>
  string(7) "seconds"
  ["last_updated"]=>
  int(1749630575)
  ["dimensions"]=>
  array(1) {
    ["uptime"]=>
    array(2) {
      ["name"]=>
      string(6) "uptime"
      ["value"]=>
      float(0)
In netdata UI it’s not showing uptime for it.
My apps_groups.conf has
wings: *wings*
Netdata Agent:
v2.5.0-194-nightly
(Previsously I was using stable channel. tried nightly only now)
Uptime to show correct value in API and show in netdata UI
Every other uptime monitoring seem to work. Only this is failing.
I suspect it’s somehow related to lxc. As it’s my only lxc node. Everything else is bare metal.
