vSphere Plugin Skip TLS verification not possible
Hi
I installed the netdata agent on a rocky linux 9.5 vm. I want it to monitor my vsphere environment. Therefore i tried to configure the vsphere plugin but the test fails with an ssl exception. There is the checkbox to skip the Skip TLS verification but i can’t click it.
Does anyone know how i can fix this? Can i manually add the argument locally on the vm?
Thank you.
With kind regards
Gianluca
@giani2000 hey. That is a bug. We will fix it tomorrow.
@ilyam8 Hi,
Okay thank you very much.
It the vnode from the vsphere plugin also a bug?
And that you can not save again if you changed something?
Thank you.
With kind regards
Gianluca
@giani2000 everything should be fixed. Thanks for reporting!
Hi @ilyam8
Thank you very much. What about the vnode issue in the vsphere plugin?
With kind regards
Gianluca
Have you created it? Check the “Vnodes” section (to the right of “Jobs”).
can you please show me where i can do this?
Thank you.
never mind, i found it
