web embedded charts stopped functioning
i have a web page that has some charts embedded using the dashboard.js method,
  						<div class="horizontal-rule"></div>
  		  					 <div data-netdata="system.load"
  			  				 data-host="http://192.168.1.113:19999/"
  			  				 data-title="SATURN (NAS) SYSTEM LOAD"
  			  				 data-width="33%"
  			  				 data-height="150PX"
  			   				 data-after="-18000"
  			   				 data-before="0"
  			   			</div>
i have 4 servers that display info in that page, 2 servers have stopped displaying info, in browser dev tools , i see this, GET http://192.168.1.113:19999/api/v1/chart=system.load&format=json&points=74&group=average&gtime=0&options=ms|flip|jsonwrap|nonzero&after=-18000?_=1699793477264 404 (Not Found)…if i click the link in dev tools i get a page that says, Unsupported API command: chart=system.load&format=json&points=74&group=average&gtime=0&options=ms|flip|jsonwrap|nonzero&after=-18000
if i try to look at a internal; demo page such as , http://192.168.1.113:19999/demo.html it fails as well
as well as http://192.168.1.113:19999/dashboard.html page will open doesn’t display any charts
as i been touble shooting ive noticed some of the links to examples, such as Netdata Dashboard
display the same error
couple servers are still displaying data in web page properly
any suggestion would be appreciated
os is linux
i have updated to latest version of netdata
Hi, @kevin_yeakley. Thanks for reporting, it is a bug. Fixed in fix v0 dashboard by ilyam8 · Pull Request #16389 · netdata/netdata · GitHub.
how can i apply this fix?..i tried reinstalling using the kickstart script diddnt seem to correct the issue
You cannot apply this fix. Wait until the next nightly version is published - tomorrow.
