I need help, is it possible for zeros to appear on the chart?
When the dimension on the chart is zero it does not appear, but it is very important to show it on my chart.
Best Regards
Best Regards
Hi OdysLam,
Only now have I seen your message.
My problem is already solved. Thank you anyway.
Hello Team,
I cannot find the setting for this field in the latest version. Iām using Netdata cloud.
Can someone help me?
Regards,
Hi, @Richard_Barrantes. Try Profile Settings ā Theme ā Which dimensions to show?
Thanks a lot @ilyam8
