I checked my cloud dashboard for monitoring and found that 8 out of my 10 nodes are offline. Though the node have Netdata agent running on each and claimed.
I have tried to restarted the agents on the nodes but it still does not work.
Environment/Browser/Agent’s version
The agents use the Ubuntu linux OS. Version 20.04 and 22.04.
I expect the nodes to show online and metrics of whatever my agents are consuming.
There has been an issue with version v1.39.0-97 of the agents which caused cloud connectivity issues. The issue is fixed in later nightly versions. The agent should update itself, or you could also manually run the netdata-updater script.
