1m_unmatched
Web Server | Web log
In a webserver, all activity should be monitored. By default, most of the webservers log activity in an access.log file. The access log is a list of all requests for individual files that people or bots have requested from a website. Log File strings include notes about their requests for the HTML files and their embedded graphic images, along with any other associated files that are transmitted.
The Netdata Agent calculates the percentage of unparsed log lines over the last minute. These are entries in the log file that didn’t match in any of the common pattern operations of the webserver (1XX, 2XX, etc). This can indicate an abnormal activity on your web server, or that your server
is performing operations that you cannot monitor with the Agent.
Web servers like NGINX and Apache2 gives you the ability to modify the log patterns for each request. If you have done that, you will also need to adjust the Netdata Agent to parse those patterns.
Troubleshooting section:
Create a custom log format job
This alert is triggered by the python.d.plugin. You must create a new job in the web_log collector for your Agent.
See how you can configure this collector
Follow the job template specified in the default web_log.conf file , focus on the lines 83:85 where you can see how you define a
custom_log_format. -
Restart the Netdata Agent
root@netdata # systemctl restart netdata
