web_log_1m_unmatched
Web Server | Web log
In a webserver, all activity should be monitored. By default, most of the web servers log activity in an access.log file. The access log is a list of all requests for individual files that people or bots have requested from a website. Log File strings include notes about their requests for the HTML files and their embedded graphic images, along with any other associated files that are transmitted.
The Netdata Agent calculates the percentage of unparsed log lines over the last minute. These are entries in the log file that didn’t match in any of the common pattern operations (1XX, 2XX, etc) of the webserver. This can indicate an abnormal activity on your web server, or that your server is performing operations that you cannot monitor with the Agent.
Web servers like NGINX and Apache2 give you the ability to modify the log patterns for each request. If you have done that, you also need to adjust the Netdata Agent to parse those patterns.
Troubleshooting section:
Verify that the Netdata collector can identify your web server's log formats
This alert is triggered by the the web_log module of the go.d.plugin. You need to double down that the collector can identify your web server’s log formats.
See how you can configure this collector
Check your logs and double that they follow the known fields.
If the known fields don’t cover your case, consider modifying the log parser according to your custom logs.
