Updates fails with an Error “Permission denied” every time
# bash <(curl -Ss https://my-netdata.io/kickstart-static64.sh)
--- Found existing install of Netdata under: /opt/netdata ---
--- Attempting to update existing install instead of creating a new one ---
[/var/lib/fail2ban]# /opt/netdata/usr/libexec/netdata/netdata-updater.sh --not-running-from-cron
Mo 17. Jan 10:38:29 CET 2022 : INFO: Checking if a newer version of the updater script is available.
/opt/netdata/usr/libexec/netdata/netdata-updater.sh: line 120: /tmp/netdata-test.pcBiIZOo7D: Permission denied
/opt/netdata/usr/libexec/netdata/netdata-updater.sh: line 120: /tmp/netdata-test.M5DBi1vyIm: Permission denied
Mo 17. Jan 10:38:30 CET 2022 : INFO: Entering /tmp/netdata-updater-0RZujQJrGk
Mo 17. Jan 10:38:30 CET 2022 : INFO: Current Version: 00103200100071
Mo 17. Jan 10:38:30 CET 2022 : INFO: Latest Version: 00103200100078
Mo 17. Jan 10:38:30 CET 2022 : INFO: Update available
Mo 17. Jan 10:38:30 CET 2022 : ERROR: FAILED TO UPDATE NETDATA : Static binary checksum validation failed. Stopping netdata installation and leaving binary in /tmp/netdata-updater-0RZujQJrGk\nUsually this is a result of an older copy of the file being cached somewhere and can be resolved by simply retrying in an hour.
FAILED
ABORTED Failed to update existing Netdata install
Can anyone lead me to the solution? What can I do?
Regards
Mon 17 Jan 2022 07:24:54 PM CET : INFO: Checking if a newer version of the updater script is available.
Mon 17 Jan 2022 07:24:55 PM CET : INFO: Downloading newest version of updater script.
/opt/netdata/usr/libexec/netdata/netdata-updater.sh: line 120: /tmp/netdata-test.asd1ZONNKe: Permission denied
/opt/netdata/usr/libexec/netdata/netdata-updater.sh: line 120: /tmp/netdata-test.eZZX7iWTkO: Permission denied
/opt/netdata/usr/libexec/netdata/netdata-updater.sh: line 233: /tmp/netdata-updater-Oz8emSkRcb/netdata-updater.sh: Permission denied
# ll /tmp/netdata-updater-Oz8emSkRcb/netdata-updater.sh
-rwxr-xr-x 1 root root 21012 Jan 17 19:24 /tmp/netdata-updater-Oz8emSkRcb/netdata-updater.sh
Ok, My problem is, I do have the mount option noexec for /tmp
Must be omitted,
I did mount /tmp/ -o remount
then a second try was successul
As a newbie to netdata, I would say build the updater to be called using sh, then there is no harm if someone has mounted their /tmp with noxec, or use a different path…
But otherwise great feature, I’m thrilled.
Thanks for your time and thanks for netdata.
Bernd
The updater itself should work fine if invoked with a plain, POSIX-compliant shell, and it should be handling temporary directories correctly (it should try $TMPDIR, /tmp, and then the current working directory, in that order, searching for the first that is both writable and allows execution). It looks like you may have stumbled across a bug in the updater itself here, independent of the checksum validation issue for static builds.
mount /tmp -o remount,exec
Mi 19. Jan 09:36:51 CET 2022 : INFO: Checking if a newer version of the updater script is available.
Mi 19. Jan 09:36:51 CET 2022 : INFO: Entering /tmp/netdata-updater-XB48GRLcP1
Mi 19. Jan 09:36:51 CET 2022 : INFO: Current Version: 00103200100078
Mi 19. Jan 09:36:51 CET 2022 : INFO: Latest Version: 00103200100096
Mi 19. Jan 09:36:51 CET 2022 : INFO: Update available
Mi 19. Jan 09:36:52 CET 2022 : ERROR: FAILED TO UPDATE NETDATA : Static binary checksum validation failed. Stopping netdata installation and leaving binary in /tmp/netdata-updater-XB48GRLcP1\nUsually this is a result of an older copy of the file being cached somewhere and can be resolved by simply retrying i
Hm, could be your “netdata-updater.sh” doesn’t contain the fix and the script self auto-update doesn’t work for some reason.
