Bad Blocks Monitoring
Configuring of the S.M.A.R.T Integration for monitoring bad blocks.
Recently we had both our disk failure in our RAID 1 Configuration. And as a result I’m looking to implement more proactive monitoring into our infrastructure to be more proactive.
I’ve completed the configuration of S.M.A.R.T but I’m not seeing any logs generated or anything retraining to SMART in the console.
This is the configuration of my python.d/smartd_log.conf
local:
  log_path : '/var/log/smartd/'
smartmon-scan:
  log_path: '/var/log/smartd/'
I’m new to netdata, so if I’m doing this wrong, please point in the right direction on the documentation and I’ll do some reading.
https://github.com/netdata/netdata/tree/master/collectors/python.d.plugin/smartd_log
Server: Amazon EC2 Instance
OS: Ubuntu 22.04.3 LTS (Jammy Jellyfish)
Agent Version: v1.42.0-159-nightly
Hi @RodoggA
So, if I understand correctly, there’s nothing under /var/log/smartd/ ? Is smartd running?
I forget to check the most basic thing. Thanks.
There appears to be issues with that service. Leave this with me.
I’ll troubleshoot that and cycle back here if I’m still not getting alerts coming through once resolved.
