Child node logs are unavailable on Parent when Child is offline.
I have successfully configured multiple child nodes streaming to a single parent. It is functioning as expected. Clicking on the “Logs” tab in Netdata, I am able to see in realtime the systemd logs of the parent and all children. This is awesome.
However, if I take a child offline and refresh the “Logs” tab, the child nodes logs are no longer available for viewing. A major use case (for us) in streaming the logs from child → parent is to assist in root cause analysis of child node failures.
- Configure Netdata Parents to centralize metrics | Learn Netdata
- Systemd Journal Logs | Learn Netdata
- Parent: v1.45.5
- Children: v1.47.5
When the child node goes offline, I am still able to see the historical systemd logs for the offline child via the parent node dashboard.
