I have a Parent node that has multiple child nodes streaming data to it. I want to enable exporting systemd journal logs of children nodes to Influxdb database. How can I do it?
I’m already exporting children nodes metrics to Influxdb using telegraf, but that doesnt contain systemd-journal-logs.
I’ve setup children nodes to stream their systemd logs to the Parent node using this doc Passive journal centralization with encryption using self-signed certificates | Learn Netdata
I’m able to see children logs on Parent node. -
I’ve setup Parent-child streaming.
I’ve setup exporting metrics of all nodes (Parent and all children) to influxdb using telegraf., using data from url http://netdata:19999/api/v1/allmetrics?format=prometheus_all_hosts
Parent Node:
Netdata version: v2.1.0-38-nightly
System info:
Type: docker
O/S version:Ubuntu, 20.04.6 LTS (Focal Fossa)
Architecture:aarch64
Kernel:Linux, 5.10.104-tegra
Children nodes:
Netdata version: v1.47.5
Type: lxc
O/S version:Ubuntu, 22.04.4 LTS (Jammy Jellyfish)
Kernel:Linux, 5.15.136-tegra
I expect to see systemd-journal-logs of all the children nodes on Influxdb. (I’ve attached a screenshot of systemd-journal logs panel)
