John
February 4, 2022, 10:16am
#1
Hi All,
We have netdata containers capturing metrics from underlying hosts and have the following question.
Environment
netdata container v1.31.0-403
RHEL8.2 host, rsyslog running on port 514
Configured settings in ‘health_alarm_notify.conf’
SEND_SYSLOG=“YES”
SYSLOG_FACILITY=‘daemon’
DEFAULT_RECIPIENT_SYSLOG=‘daemon.notice@10.195.225.51:514/netdata’
How can we send errors, alarms & even metrics from the containers to the underlying host rsyslog?
netdata logs, alarms & metrics appear in /var/log/messages
Cheers,
John.
ilyam8
February 4, 2022, 7:22pm
#2
Hi, @John .
John:
send errors
Docker has the syslog logging driver . Using it should do.
John:
send alarms
I see you have found Netdata has syslog notification methond and configured it. Does it work?
John:
send metrics
Not sure it is possible, unfortunately. Consider using any other supported by Netdata exporting connector .
John
February 7, 2022, 1:42pm
#3
Thanks @ilyam8 , worked OK.
Just on the exporting connector, would netdata consider developing an exporter for Splunk?
Cheers,
John.
Hi @John . What exactly you need to export? netdata collected metrics or netdata logs?
btw, we are thinking of developing a log collection, aggregation and querying feature in netdata and we need some help identifying an MVP. Would you be interested to help?
John
February 15, 2022, 5:42am
#5
Hi @Costa_Tsaousis ,
Costa:
The netdata metrics via syslog at this stage, preferably in a key/value format. Something similar to Cisco’s CNR/DHCP activity output?;
02/15/2022 15:36:23 name/dhcp/1 Activity Server 0 05320 DHCP activity, 60s: Tot. Recd: 220, Tot. Sent: 174, Discovers: 67, Offers: 37, Requests: 141, Acks: 137, Nacks: 0, Rel.: 12, Decl.: 0, Informs: 0, Lease queries: 0, Bootp: 0 Exp.: 0, Dropped: 34 (DRL: 0), In use: Resp: 3, Req: 3, Acks/Second: 2.
Costa:
Yes am interested as time permits.
Cheers,
John.
