Sending metrics to ElasticSearch via syslog-ng
I want to send both default and custom metrics from netdata to ElasticSearch, but I can’t use Graphite or Prometheus as stated in the docs. I looked for an alternative online and found a guide on how to do this via syslog-ng: link.
I like this approach and am trying to implement it.
I am first trying to store the metrics locally in a file, before starting to try to connect to elastic.
I have installed syslog-ng and have a working instance of netdata too, collecting custom metrics as well. However I can’t seem to get the metrics to be stored in a file following this guide above.
Could you give me a hand? Or guide me on how to implement something similar?
Nvidia Jetson TX2 running on Ubuntu (L4T); Netdata version 1.33.1-217-gc380b984d
Hello @Inigo_Arribillaga,
This is a pretty old guide and not actually written by Netdata. I am not sure that this functionality is possible with any workaround at the moment. You can open a feature request for the Agent or an GH discussion to raise awareness about this feature.
OK that’s fine, thank you for your time.
I would like to ask you another question.
Can netdata write sampled data to a file, so that I can gather this info with for example filebeat?
This might help you
Netdata also ships nc-exporting.sh, a script that can be used as a fallback exporting connector to save the metrics to disk and push them to the time-series database when it becomes available again. It can also be used to monitor / trace / debug the metrics Netdata generates.
If you need you can also find this in our docs here - Exporting reference | Learn Netdata
OK thanks I’ll check out your proposals.
