Could not determine debian release code name
Hi.
We cannot install NetData to one of our Jessie Debian System, can you please help ?
Proxy request sent, awaiting response... 200 OK
Length: unspecified [application/octet-stream]
Saving to: ‘/tmp/netdata-kickstart.sh’
/tmp/netdata-kickstart.sh                                [ <=>        ]  82.18K  --.-KB/s   in 0.06s
2023-03-03 11:02:05 (1.26 MB/s) - ‘/tmp/netdata-kickstart.sh’ saved [84148]
 ABORTED  Could not determine debian release code name. This is required information on these systems.
For community support, you can connect with us on:
  - GitHub: https://github.com/netdata/netdata/discussions
  - Discord: https://discord.gg/5ygS846fR6
  - Our community forums: https://community.netdata.cloud/
tmp# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux 8.6 (jessie)
Release:        8.6
Codename:       jessie
:/tmp# cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 8 (jessie)"
NAME="Debian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=debian
HOME_URL="http://www.debian.org/"
SUPPORT_URL="http://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
Hi @pgro
Thanks for this. This has been a recent change from what I see, we will try to fix asap.
Thanks!
Does this system have a /etc/os-release or /usr/lib/os-release files? Can you please list their contents? Thanks!
Already included above, but here it is
ls -l /etc/os-release
lrwxrwxrwx 1 root root 21 Sep 12  2016 /etc/os-release -> ../usr/lib/os-release
root@xxx:~# cat /etc/os-release
VERSION_ID="8"
ID=debian
(Ah, didn’t scroll).
It should be fixed by this → Fix handling of missing release codename on DEB systems. by Ferroin · Pull Request #14642 · netdata/netdata · GitHub thank you for reporting!
Oh great , so I have to kickstart again and that would download the updated install file ? Ok I will try it
