Getting below for upgrade:
Connecting to my-netdata.io (my-netdata.io)|104.21.13.159|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: unspecified [application/octet-stream]
Saving to: ‘/tmp/netdata-kickstart.sh’
/tmp/netdata-kickstart.sh [ <=> ] 61.94K --.-KB/s in 0.002s
2022-04-29 20:21:35 (39.5 MB/s) - ‘/tmp/netdata-kickstart.sh’ saved [63429]
— Checking for existing installations of Netdata… —
WARNING Found an existing netdata install at /, but could not determine the install type.
WARNING Usually this means you installed Netdata through your distribution’s regular package repositories or some other unsupported method.
- Found an existing netdata install at /, but could not determine the install type.
- Usually this means you installed Netdata through your distribution’s regular package repositories or some other unsupported method.
ABORTED We do not support trying to update or claim installations when we cannot determine the install type. You will need to uninstall the existing install using the same method you used to install it to proceed.
Any idea on how to upgrade?
Hello @hellreturn
Could you provide us with some more information?
Verify your current build info netdata -W buildinfo.
Issue still persist:
Version: netdata v1.34.0-67-nightly
Configure options: '--prefix=/usr' '--sysconfdir=/etc' '--localstatedir=/var' '--libexecdir=/usr/libexec' '--libdir=/usr/lib' '--with-zlib' '--with-math' '--with-user=netdata' '--with-bundled-protobuf' 'CFLAGS=-O2' 'LDFLAGS='
Install type: unknown
Features:
dbengine: YES
Native HTTPS: YES
Netdata Cloud: YES
ACLK Next Generation: YES
ACLK Legacy: NO
TLS Host Verification: YES
Machine Learning: YES
Stream Compression: NO
Libraries:
protobuf: YES (bundled)
jemalloc: NO
JSON-C: YES
libcap: NO
libcrypto: YES
libm: YES
tcalloc: NO
zlib: YES
Plugins:
apps: YES
cgroup Network Tracking: YES
CUPS: NO
EBPF: YES
IPMI: NO
NFACCT: NO
perf: YES
slabinfo: YES
Xen: NO
Xen VBD Error Tracking: NO
Exporters:
AWS Kinesis: NO
GCP PubSub: NO
MongoDB: NO
Prometheus Remote Write: NO
Please consider running kickstart script with the --reinstall-clean option. This won’t affect your current configuration under /etc/netdata but just in case perform a backup (on this folder) if you had made any changes in the configuration of your Netdata deployment.
