Greetings!
Apologies as I’ve seen a few similar posts but have had no luck so far.
I’m attempting to delete my Offline previously registered nodes. In the browser navigating to (https://app.netdata.cloud/ ) Rooms → All nodes → Room settings → Nodes
I can see 3 copies of my Nodes 3 being Offline however the option to remove is disabled “Remove is Disabled”
In other posts I’ve read if they are offline they should be able to be removed but in this case can’t seem to get them pulled out. Thanks!
