I can see plenty of information on my docker containers when I login to the local web interface on port 19999 of my EC2 instance which is running straight docker containers:
But no information on the individual containers is seen when I login to the cloud interface:
Why can’t I see my running containers on the cloud interface?
How can I get the cloud interface to show my docker containers?
-RP
Please see AmazonLinux2 Installation -- is there an RPM? - #4 by rpalmer-koverly for details on installing netdata on AmazonLinux 2 from scratch using the EPEL repository, and the results seen for running docker containers on the local interface versus the cloud interface.
Hint: They’re seen locally, but not on the cloud interface.
OK, thanks. It’d be more super helpful to me to be able to arrow in to a specific docker container like on the local port 19999 interface instead of having to drill in through cgroups → cpu/mem/disk/net and then adjust the Group By and then select the specific Instance.
Looking forward to bug Issue 564’s resolution.
-RP
