Graph colour schemes are not consistent
The colour scheme used by the same graphs on different pages are not consistent. This makes it difficult to quickly read/understand graphs and is bad UX.
For example, on the Overview tab, the “system.ram” graph uses the scheme:
  • buffers: green
  • cached: red
  • free: blue
  • used: orange
While on node tabs the scheme is:
  • buffers: orange
  • cached: blue
  • free: green
  • used: red
And when you add the graph to a dashboard it’s:
  • buffers: blue
  • cached: red
  • free: orange
  • used: green
Environment/Browser
Any browser.
Graphs displaying the same information should have the same colour scheme in all views. In this case, it seems that the colours used on the node tabs make the most sense. It certainly doesn’t make sense for “used” to be green!
I do note that disk_space graphs do maintain the same colours on both node tabs and dashboards, but at the very least “system.ram” and “system.cpu” do not. “system.cpu” even displays in completely different colours on different node tabs, seemingly depending on whether a “nice” dimension is present or not.
Hi Stuart!
Thank you for your valuable feedback!
I’ll pass your comments to our Product and UX team to take a look at the consistency the color schemes are populated on the charts.
I’ll keep you posted for any updates,
Georgia
Hi, may I jump onto this thread as I have the challenge of the Apache worker graph showing both idle and busy in almost the same blue, making them unreadable without carefully hovering over the graph. Any ideas how the colour for either idle or busy can be changed?
Thank you.
