Haproxy go.d configuration for stats page
We are moving from python.d collectors and have problem with go.d version. Our configuration is:
haproxy.cfg:
listen stats
 bind :::1936
 stats enable
 stats uri /
python.d/haproxy.conf
socket: '/var/run/haproxy/admin.sock'
Now how to configure haproxy go.d collector?
go.d/haproxy.conf:
jobs:
 - name: local
   url: http://[::1]:1936/;csv
[ DEBUG ] build[manager] build.go:154 received config group ('/etc/netdata/go.d/haproxy.conf'): 1 jobs (added: 1, removed: 0)
[ DEBUG ] build[manager] build.go:303 building haproxy[local] job, config: map[__provider__:file reader __source__:/etc/netdata/go.d/haproxy.conf autodetection_retry:0 module:haproxy name:local priority:70000 update_every:1 url:http://127.0.0.1:1936/;csv]
[ ERROR ] haproxy[local] haproxy.go:80 unsupported character in float
[ ERROR ] haproxy[local] job.go:191 check failed
go.d/haproxy.conf:
jobs:
 - name: local
   url: http://127.0.0.1:1936/
[ DEBUG ] build[manager] build.go:303 building haproxy[local] job, config: map[__provider__:file reader __source__:/etc/netdata/go.d/haproxy.conf autodetection_retry:0 module:haproxy name:local priority:70000 update_every:1 url:http://127.0.0.1:1936/]
[ ERROR ] haproxy[local] haproxy.go:80 "INVALID" is not a valid start token
Even using ’ or " doesn’t work.
agent 1.38.1
Data from stats page. Curl under netdata user returns stats data.
From the documentation it looks like the PROMEX module is required. That module exposes the metrics in the Prometheus format, accessible by default at http://xxx:8404/metrics, based on what I see in the config file.
I’m personally not sure what’s on port 1936 or what the ;csv is supposed to mean, perhaps this is a legacy way of exporting metrics that the old collector used.
Thank you, i missed this part. Anyway, i must revert to python.d module because netdata go.d module supports backends stats only.
We need to extend it to support the other metrics too then. @ilyam8 ?
We used to monitor our haproxy installation with netdata, but recently found out it doesn’t work anymore.
We keep getting this error, no matter what:
ERR haproxy/haproxy.go:85 failed to parse prometheus metrics: expected a valid start token, got “<” (“INVALID”) while parsing: “<” collector=haproxy job=local
As I remember it, it used to work through sockets (/run/haproxy/admin.sock), but it doesn’t seem to work like that anymore?
