Hello Netdata,
how to active trigger action on active alerts on netdata
omskalpesh@gmail.com
Hi @kalpesh_oms ,
Thanks for raising your doubt on the forums.
Is your question on triggering actions from Alerts? Also is this on the Netdata Agent?
If so you probably can look into this:
Another user had asked something similar here, How to trigger the firewall to close port 25 on critical alarm on postfix mail queue?.
If it is on Netdata Cloud, we have plans to further enhance our notification options but at the moment we don’t have anything to support what you are asking.
Regards,
Hugo
