Is there a way to save log filters? I am evaluating Netdata for a client and would like to use Netdata for centralized log management - we’d ship everything to it, system logs, HTTP logs, application logs, etc.
As you’d expect the default log view will quickly become an unmanageable firehose of noise, so I would like to save predefined filters like “HTTP logs” and so on (based on log source/systemd unit), so their admins can quickly narrow down onto what they’re interested in.
It doesn’t look like I can save filters in any way? It would mean every time they switch to the logs tab in Netdata they’d have to rebuild their filter from scratch using options in the sidebar?
Surely that’s not right and I’m just an idiot for not seeing an obvious option somewhere?
Netdata build info:
netdata -W buildinfo
time=2025-11-01T15:19:30.242Z comm=netdata source=daemon level=notice errno="2, No such file or directory" tid=72533 msg="CONFIG: cannot load user config '/etc/netdata/stream.conf'. Will try stock config."
Packaging:
Netdata Version ____________________________________________ : v2.7.3
Package Distro _____________________________________________ : debian 13
Configure Options __________________________________________ : cmake -DCMAKE_BUILD_TYPE=RelWithDebInfo -DCMAKE_C_STANDARD=11 -DCMAKE_CXX_STANDARD=14 -DBUILD_SHARED_LIBS= -DCMAKE_C_FLAGS=' -fexceptions -fexceptions -fno-omit-frame-pointer -funwind-tables -fasynchronous-unwind-tables' -DCMAKE_CXX_FLAGS=' -fexceptions -fexceptions -fno-omit-frame-pointer -funwind-tables -fasynchronous-unwind-tables' -DCMAKE_COMPILE_DEFINITIONS='_GNU_SOURCE' -DCMAKE_EXE_LINKER_FLAGS=' -fexceptions -fexceptions -rdynamic' -DCMAKE_SHARED_LINKER_FLAGS=''
Default Directories:
Operating System:
Kernel Version _____________________________________________ : 6.12.41+deb13-amd64
Operating System ___________________________________________ : Debian GNU/Linux
Operating System ID ________________________________________ : debian
Operating System ID Like ___________________________________ : unknown
Operating System Version ___________________________________ : 13 (trixie)
Hardware:
CPU Cores __________________________________________________ : 32
CPU Frequency ______________________________________________ : 5759000000
RAM Bytes __________________________________________________ : 134133297152
Disk Capacity ______________________________________________ : 4800963944448
CPU Architecture ___________________________________________ : x86_64
Virtualization Technology __________________________________ : none
Container:
Features:
Streaming and Replication Compression ______________________ : YES (zstd lz4 gzip brotli)
Memory Allocator ___________________________________________ : system
Database Engines:
dbengine (compression) _____________________________________ : YES (zstd lz4)
Connectivity Capabilities:
Libraries:
Brotli (generic-purpose lossless compression algorithm) ____ : YES
libcap (Linux capabilities system operations) ______________ : YES
libmnl (library for working with netfilter) ________________ : YES
stacktraces (library for getting stack traces) _____________ : libbacktrace (mmap, threads, data)
Plugins:
windows (monitor Windows systems) __________________________ : NO
network-viewer (monitor TCP/UDP IPv4/6 sockets) ____________ : YES
systemd-journal (monitor journal logs) _____________________ : YES
windows-events (monitor Windows events) ____________________ : NO
Xen ________________________________________________________ : YES
Exporters:
Debug/Developer Features:
Runtime Information:
Profile ____________________________________________________ : standalone
Stream Parent (accept data from Children) __________________ : NO
Stream Child (send data to a Parent) _______________________ : NO
Total System Memory ________________________________________ : 134133297152
Available System Memory ____________________________________ : 132159975424
