I am new to netdata and wonder if it is possible to see the process name that wrote to disk at a specific time. In this example, a process has written a lot of stuff to disk at 17:42:06, but the graph only shows “other”. How can I see the exact process name that caused this disk load?
Thank you for your help.
My system:
$ netdata -v
netdata v1.37.1
$ netdata -W buildinfo
Version: netdata v1.37.1
Configure options: '--build=x86_64-linux-gnu' '--prefix=/usr' '--includedir=${prefix}/include' '--mandir=${prefix}/share/man' '--infodir=${prefix}/share/info' '--sysconfdir=/etc' '--localstatedir=/var' '--disable-option-checking' '--disable-silent-rules' '--libdir=${prefix}/lib/x86_64-linux-gnu' '--runstatedir=/run' '--disable-maintainer-mode' '--disable-dependency-tracking' '--libdir=/usr/lib' '--libexecdir=/usr/lib' '--disable-cloud' '--enable-x86-sse' '--disable-exporting-prometheus-remote-write' '--enable-dbengine' '--enable-https' '--enable-plugin-cups' '--enable-plugin-nfacct' '--with-math' 'build_alias=x86_64-linux-gnu' 'CFLAGS=-g -O2 -ffile-prefix-map=/build/netdata-aGlU9O/netdata-1.37.1=. -fstack-protector-strong -Wformat -Werror=format-security -Wall -O3' 'LDFLAGS=-Wl,-z,relro -Wl,-z,now -Wl,--as-needed' 'CPPFLAGS=-Wdate-time -D_FORTIFY_SOURCE=2' 'CXXFLAGS=-g -O2 -ffile-prefix-map=/build/netdata-aGlU9O/netdata-1.37.1=. -fstack-protector-strong -Wformat -Werror=format-security'
Install type: unknown
Features:
dbengine: YES
Native HTTPS: YES
Netdata Cloud: NO (by user request)
ACLK: NO
TLS Host Verification: YES
Machine Learning: NO
Stream Compression: YES
Libraries:
protobuf: YES (system)
jemalloc: NO
JSON-C: YES
libcap: YES
libcrypto: YES
libm: YES
tcalloc: NO
zlib: YES
Plugins:
apps: YES
cgroup Network Tracking: YES
CUPS: YES
EBPF: NO
IPMI: NO
NFACCT: YES
perf: YES
slabinfo: YES
Xen: NO
Xen VBD Error Tracking: NO
Exporters:
AWS Kinesis: NO
GCP PubSub: NO
MongoDB: NO
Prometheus Remote Write: NO
Debug/Developer Features:
Trace Allocations: NO
