I have 2 dedicated servers and 5 virtualised servers all running ubuntu 18.04 LTS, While I can install netdata on each server I was wondering if it’s possible to have it all go under one dashboard. I already have set up a registry and wish to avoid netdata cloud unless I can self-host that as well.
Hi @ShadowStorm!
As far as I know, you can’t host Netdata Cloud yourself.
But you can stream metrics from all your nodes to one parent node. That will allow you to see your child nodes metrics from the parent node.
