I am using my own httpcheck.conf on one of my nodes. This conf went through multiple iterations of changes. One of the early iterations had multiple wrongly configured alerts that would trigger 100% of the time. I have since removed and changed these alerts, but the original critical warning still persists in the dashboard.
I know that I usually remove alerts by “fixing” the issue, but this is not possible in this case. Silencing is also not an option, because I am using the same default alarm in my current conf. The service has been restarted many times.
Current OS is Linux Ubuntu 22.
I want to remove the old alerts / refresh the node.
