Environment
Amazon Linux 2
Problem Diagnose
Installation using curl from https://my-netdata.io/kickstart.sh yields:
systemctl status netdata.service
Loaded: loaded (/usr/lib/systemd/system/netdata.service; enabled; vendor preset: disabled)
Active: inactive (dead) (Result: exit-code) since Wed 2021-04-14 23:58:40 UTC; 52min ago
Process: 7996 ExecStartPre=/bin/mkdir -p /var/cache/netdata **(code=exited, status=226/NAMESPACE)**
Main PID: 1421 (code=exited, status=0/SUCCESS)
Apr 14 23:58:40 ip-172-31-162-162.ec2.internal systemd[1]: **Failed to start Real time performance monitoring.**
Apr 14 23:58:40 ip-172-31-162-162.ec2.internal systemd[1]: **Unit netdata.service entered failed state.**
Apr 14 23:58:40 ip-172-31-162-162.ec2.internal systemd[1]: **netdata.service failed.**
Apr 14 23:58:40 ip-172-31-162-162.ec2.internal systemd[1]: Stopped Real time performance monitoring.
It seems like it cannot create the /var/cache/netdata folder, even if cleaned via rm -rf or through the uninstaller.
The install process also cannot start the service via systemctl and reverts back to executing /usr/sbin/netdata directly.
Folder DOES get created, but it seems there might be either a timing or validation issue upon service start
