Installation stuck, how to uninstall now?
I’m on Centos 7, Apache 2.4.
Installation froze when looking for libuv:
 --- Checking for libuv availability. ---
Importing GPG key 0xF6FB8FD3:
 Userid     : "https://packagecloud.io/firehol/netdata (https://packagecloud.io/docs#gpg_signing) <support@packagecloud.io>"
 Fingerprint: a799 ab70 2ea6 dee3 e21a a716 b418 8b90 f6fb 8fd3
 From       : https://packagecloud.io/netdata/netdata/gpgkey
Been sitting there for an hour, it’s time to call it a day…
Before and if I reinstall, can someone advise on how to completely uninstall at this point?
I know at least some dependencies must have been installed, and possibly some application files, but I have since lost track of which…
Hello @nonhocapito and welcome in our community. To overcome this issue please run the kickstart script just as you copied it from Install Netdata with kickstart.sh | Learn Netdata or your Netdata Cloud and add the --non-interactive parameter, if it stacks anywhere just press enter. It’s an issue that we are aware of with the Centos systems.
Note: At this moment this will install the Agent with binary packages for your architecture. So the Agent will be installer under /opt/netdata.
