During monitoring I sometimes have cpu spikes caused by an application and a process but can I know the id of the process?
For example the java process when it has a load I would like to know which id’s to be able to search it in the system.
Thank you very much for your attention. Thanks a lot for your attention.
No, not yet, unfortunately. We have a feature coming that will display a lot of info on running processes on a table format, but it’s still in development.
What I can suggest is, if the various java processes on your node have differences between them in the way they are presented in ps
, perhaps you can split them into smaller groups than just java
, bymodifying apps_groups.conf
Thank you very much for the clarification, we will try the above.
Thank you very much it worked for me one last question that I don’t know if it is possible I would like to launch a message when the process in particular exceeds a % of cpu for example:
alarm: cpu_template
on: apps.cpu
lookup: average -10s percentage foreach process1,process2,process3, …
every: 1s
warn: $this > 60
crit: $this > 90
to: sysadmin
Should it work? Or can’t it be done? Thanks
You got it, except that the “foreach” parameters would need to be the process groups defined in apps_grouos.conf, i.e. the exact dimensions yiu see in the chart. These aren’t individual processes, but groups of processes matching the names defined for each process group
Once again, thank you! @Christopher_Akritid1 !!
