Load Average Randomly Reads Hundreds Times Higher Than Actual
Hello all,
I am encountering a strange problem where my nodes randomly will show on NetData as hundreds of times higher than reported on the server. You can see in the below image that 4 of 5 of them are reporting super high numbers.
All nodes running Proxmox, latest kernel:
root@lunar3:~# uname -a
Linux lunar3 6.5.11-8-pve #1 SMP PREEMPT_DYNAMIC PMX 6.5.11-8 (2024-01-30T12:27Z) x86_64 GNU/Linux
They are reporting this way directly on the NetData instance running on the nodes as well, so I know its not with the site:
Have tested on Chrome, Edge, Opera, Firefox; Same result.
root@lunar3:~# /opt/netdata/bin/netdata -v
netdata v1.45.4
root@lunar3:~# /opt/netdata/bin/netdata -W buildinfo
Packaging:
    Netdata Version ____________________________________________ : v1.45.4
    Installation Type __________________________________________ : kickstart-static
    Package Distro _____________________________________________ : unknown
    Configure Options __________________________________________ : dummy-configure-command
Default Directories:
    User Configurations ________________________________________ : /opt/netdata/etc/netdata
    Stock Configurations _______________________________________ : /opt/netdata/usr/lib/netdata/conf.d
    Ephemeral Databases (metrics data, metadata) _______________ : /opt/netdata/var/cache/netdata
    Permanent Databases ________________________________________ : /opt/netdata/var/lib/netdata
    Plugins ____________________________________________________ : /opt/netdata/usr/libexec/netdata/plugins.d
    Static Web Files ___________________________________________ : /opt/netdata/usr/share/netdata/web
    Log Files __________________________________________________ : /opt/netdata/var/log/netdata
    Lock Files _________________________________________________ : /opt/netdata/var/lib/netdata/lock
    Home _______________________________________________________ : /opt/netdata/var/lib/netdata
Operating System:
    Kernel Version _____________________________________________ : 6.5.11-8-pve
    Operating System ___________________________________________ : Debian GNU/Linux
    Operating System ID ________________________________________ : debian
    Operating System ID Like ___________________________________ : unknown
    Operating System Version ___________________________________ : 12 (bookworm)
Hardware:
    CPU Cores __________________________________________________ : 80
    CPU Frequency ______________________________________________ : 2700000000
    RAM Bytes __________________________________________________ : 135089475584
    Disk Capacity ______________________________________________ : 119453777920
    CPU Architecture ___________________________________________ : x86_64
    Virtualization Technology __________________________________ : none
Container:
Features:
Database Engines:
    dbengine ___________________________________________________ : YES
Connectivity Capabilities:
Libraries:
Plugins:
    cups (monitor printers and print jobs) _____________________ : NO
    freeipmi (monitor enterprise server H/W) ___________________ : NO
    Xen ________________________________________________________ : NO
    Logs Management ____________________________________________ : NO
Exporters:
    MongoDB ____________________________________________________ : NO
Debug/Developer Features:
root@lunar3:~# /opt/netdata/bin/netdatacli aclk-state
ACLK Available: Yes
ACLK Version: 2
Protocols Supported: Protobuf
Protocol Used: Protobuf
MQTT Version: 5
Claimed: Yes
Claimed Id: --redacted--
Online: Yes
Reconnect count: 0
Banned By Cloud: No
Last Connection Time: 2024-05-12 13:30:09
Last Connection Time + 3 PUBACKs received: 2024-05-12 13:30:09
Received Cloud MQTT Messages: 1159
MQTT Messages Confirmed by Remote Broker (PUBACKs): 1300
> Node Instance for mGUID: "--redacted--" hostname "lunar3"
        Claimed ID: --redacted--
        Node ID: --redacted--
        Streaming Hops: 0
        Relationship: self
        Alert Streaming Status:
                Updates: 1
                Pending Min Seq ID: 0
                Pending Max Seq ID: 0
                Last Submitted Seq ID: 129
I have no idea where to start with this. It’s possible that NetData is calculating it’s own average based on factors unknown to me.
Nodes 3 & 4 are fresh proxmox installs with no containers or vm’s on them.
Appreciate any insight!
thanks for reporting that, this is related to the fact that we were applying ucum units on the load metrics having the units as “m load” (more details on this discord thread)
this had been fixed on the Metrics tab but seems it didn’t apply on the Nodes tab. we will be fixing it
