Is there any way to set manually the server offline so I can delete from the nodes?
Kind regards,
George
Kind regards,
George
Hi. Do you mean how to remove a stale child node from a parent node?
Hi. No parent node. I have just 3 nodes that the servers do not exist anymore and I don’t have access. I need to remove them from Netdata but the recycle bin icon is disabled because the node needs to be offline.
How I can set it offline and delete it?
I think it is not possible if the node is still connected.
What do you mean by “not exist anymore”? If it would be the case the node’d be offline.
I mean that the server is decommissioned and formatted. How is it possible to be connected?
Could you clarify its current status? I had assumed it was connected since you mentioned it wasn’t offline
